Two-Way Ambiguity in 2D Projective Reconstruction from Three Uncalibrated 1D Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2001
We show that there is in genral a two-way ambiguity for 2D projective reconstruction from three uncalilbrated 1D views, independent of the number of point correspondences. The two distinct projective reconstructions are exactly related by a quadratic transformation with the three camera centers as fundamental points. Unique 2D reconstruction is possible only when the three camera centers are aligned. By Carlsson duality, there is a dual two-way ambiguity for 2D projective reconstruction from six point correspondences, independent of the number of 1D views. The theoretical results are demonstrated on numerical examples.
Quan-pami01-ambiguity.pdf (205.11 Ko) Télécharger le fichier
inria-00590145 , version 1 (03-05-2011)
Long Quan. Two-Way Ambiguity in 2D Projective Reconstruction from Three Uncalibrated 1D Images. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2001, 23 (2), pp.212--216. ⟨10.1109/34.908971⟩. ⟨inria-00590145⟩
81 Consultations
278 Téléchargements
