On the properties of relative plausibilities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this paper we investigate the properties of the relative plausibility function, the probability built by normalizing the plausibilities of singletons associated with a belief function. On one side, we stress how this probability is a perfect representative of the original belief function when combined with any arbitrary probability through Dempster's rule. This leads to conjecture that this function should also be the solution of the probabilistic approximation problem, formulated naturally in terms of Dempster's rule. On the other side, the geometric properties of relative plausibilities are studied in the context of the geometric approach to the theory of evidence, yielding a description of the representation property which suggests a sketch for the general proof of our conjecture.
smc05.pdf (190.97 Ko) Télécharger le fichier
inria-00590190 , version 1 (06-05-2011)
Fabio Cuzzolin. On the properties of relative plausibilities. IEEE Systems, Man, and Cybernetics Society (SMC'05), Oct 2005, Hawai, United States. pp.594--599, ⟨10.1109/ICSMC.2005.1571211⟩. ⟨inria-00590190⟩
23 Consultations
80 Téléchargements
