The Cyclope : A 6 DOF Optical Tracker Based on a Single Camera - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this paper we describe a low-cost infrared optical device capable of tracking two targets with six DOF (Degrees Of Freedom) for interaction within both desktop and large projection applications. We use off-the-shelf components for the hardware and open-source libraries for the software.
TheCyclopeTracker.pdf (57.88 Ko) Télécharger le fichier
Format : Figure, Image
inria-00590194 , version 1 (03-05-2011)
  • HAL Id : inria-00590194 , version 1
Hervé Mathieu. The Cyclope : A 6 DOF Optical Tracker Based on a Single Camera. 2nd INTUITION International Workshop "VR/VE & Industry: Challenges and opportunities", Nov 2005, Paris, France. ⟨inria-00590194⟩
175 Consultations
167 Téléchargements
