Camera Cooperation for Achieving Visual Attention - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Machine Vision and Applications Année : 2006
In this paper we address the problem of establishing a computational model for visual attention using cooperation between two cameras. More specifically we wish to maintain a visual event within the field of view of a rotating and zooming camera through the understanding and modelling of the em geometric and kinematic coupling between a static camera and an active camera. The static camera has a wide field of view thus allowing panoramic surveillance at low resolution. High-resolution details may be captured by a second camera, provided that it looks in the right direction. We derive an algebraic formulation for the coupling between the two cameras and we specify the practical conditions yielding a unique solution. We describe a method for separating a foreground event (such as a moving object) from its background while the camera rotates. A set of outdoor experiments shows the two-camera system in operation.
Horaud_MVA2006.pdf (752.69 Ko) Télécharger le fichier
Format : Figure, Image
inria-00590202 , version 1 (03-05-2011)
Radu Horaud, David Knossow, Markus Michaelis. Camera Cooperation for Achieving Visual Attention. Machine Vision and Applications, 2006, 16 (6), pp.331--342. ⟨10.1007/s00138-005-0182-9⟩. ⟨inria-00590202⟩
237 Consultations
221 Téléchargements
