A Differential Model of the Complex Cell - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neural Computation Année : 2011
The receptive fields of simple cells in the visual cortex can be understood as linear filters. These filters can be modelled by Gabor functions, or by Gaussian derivatives. Gabor functions can also be combined in an energy model of the complex cell response. This work proposes an alternative model of the complex cell, based on Gaussian derivatives. It is most important to account for the insensitivity of the complex response to small shifts of the image. The new model uses a linear combination of the first few derivative filters, at a single position, to approximate the first derivative filter, at a series of adjacent positions. The maximum response, over all positions, gives a signal that is insensitive to small shifts of the image. This model, unlike previous approaches, is based on the scale-space theory of visual processing. In particular, the complex cell is built from filters that respond to the 2-D differential structure of the image. The computational aspects of the new model are studied in one and two dimensions, using the steerability of the Gaussian derivatives. The response of the model to basic images, such as edges and gratings, is derived formally. The response to natural images is also evaluated, using statistical measures of shift insensitivity. The relevance of the new model to the cortical image-representation is discussed.
HansardHoraud-NECO2011.pdf (1.12 Mo) Télécharger le fichier
Format : Figure, Image
inria-00590266 , version 1 (10-08-2011)
Miles Hansard, Radu Horaud. A Differential Model of the Complex Cell. Neural Computation, 2011, 23 (9), pp.2324-2357. ⟨10.1162/NECO_a_00163⟩. ⟨inria-00590266⟩
214 Consultations
199 Téléchargements
