Calibration of Central Catadioptric Cameras Using a DLT-Like Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2011
In this study, we present a calibration technique that is valid for all single-viewpoint catadioptric cameras. We are able to represent the projection of 3D points on a catadioptric image linearly with a 6×10 projection matrix, which uses lifted coordinates for image and 3D points. This projection matrix can be computed from 3D-2D correspondences (minimum 20 points distributed in three different planes). We show how to decompose it to obtain intrinsic and extrinsic parameters. Moreover, we use this parameter estimation followed by a non-linear optimization to calibrate various types of cameras. Our results are based on the sphere camera model which considers that every central catadioptric system can be modeled using two projections, one from 3D points to a unitary sphere and then a perspective projection from the sphere to the image plane. We test our method both with simulations and real images, and we analyze the results performing a 3D reconstruction from two omnidirectional images.
ijcvpaper.pdf (419.75 Ko) Télécharger le fichier
inria-00590268 , version 1 (03-05-2011)
Luis Puig, Yalin Bastanlar, Peter Sturm, Josechu Guerrero, Joao Barreto. Calibration of Central Catadioptric Cameras Using a DLT-Like Approach. International Journal of Computer Vision, 2011, 93 (1), pp.101-114. ⟨10.1007/s11263-010-0411-1⟩. ⟨inria-00590268⟩
353 Consultations
738 Téléchargements
