Minimal symmetric Darlington synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Control, Signals, and Systems Année : 2007
We consider the symmetric Darlington synthesis of a p x p rational symmetric Schur function S with the constraint that the extension is of size 2p x 2p. Under the assumption that S is strictly contractive in at least one point of the imaginary axis, we determine the minimal McMillan degree of the extension. In particular, we show that it is generically given by the number of zeros of odd multiplicity of I-SS*. A constructive characterization of all such extensions is provided in terms of a symmetric realization of S and of the outer spectral factor of I-SS*. The authors's motivation for the problem stems from Surface Acoustic Wave filters where physical constraints on the electro-acoustic scattering matrix naturally raise this mathematical issue.
BEGO2007.pdf (283.93 Ko) Télécharger le fichier
inria-00590547 , version 1 (03-05-2011)
Laurent Baratchart, Per Enqvist, Andrea Gombani, Martine Olivi. Minimal symmetric Darlington synthesis. Mathematics of Control, Signals, and Systems, 2007, 19, pp.283-311. ⟨10.1007/s00498-007-0020-x⟩. ⟨inria-00590547⟩
258 Consultations
132 Téléchargements
