Estimation of an optimal spectral band combination to evaluate skin disease treatment efficacy using multi-spectral images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sylvain Prigent
  • Fonction : Auteur
  • PersonId : 872617
Didier Zugaj
  • Fonction : Auteur
Xavier Descombes
Philippe Martel
  • Fonction : Auteur
Josiane Zerubia
Clinical evaluation of skin treatments consists of two steps. First, the degree of the disease is measured clinically on a group of patients by dermatologists. Then, a statistical test is used on obtained set of measures to determine the treatment efficacy. In this paper, a method is proposed to automatically measure the severity of skin hyperpigmentation. After a classification step, an objective function is designed in order to obtain an optimal linear combination of bands defining the severity criterion. Then a hypothesis test is deployed on this combination to quantify treatment efficacy.
icip_final.pdf (456.96 Ko) Télécharger le fichier
inria-00590694 , version 1 (04-05-2011)
  • HAL Id : inria-00590694 , version 1
Sylvain Prigent, Didier Zugaj, Xavier Descombes, Philippe Martel, Josiane Zerubia. Estimation of an optimal spectral band combination to evaluate skin disease treatment efficacy using multi-spectral images. IEEE International Conference on Image Processing (ICIP), Sep 2011, Brussels, Belgium. ⟨inria-00590694⟩
442 Consultations
252 Téléchargements
