Specifying and implementing UI Data Bindings with Active Operations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modern GUI toolkits propose the use of declarative data bindings to link the domain data to their presentations. These approaches work fine for defining simple bindings, but require an increasing programming effort as soon as the bindings become more complex. In this paper, we propose the use of active operations for specifying and implementing UI data bindings to tackle this issue. We demonstrate that the proposed approach goes beyond the usual declarative data bindings by combining the simplicity of the declarative approaches with the expressiveness of active operations.
EICS_2011.pdf (671.71 Ko) Télécharger le fichier
inria-00590896 , version 1 (05-05-2011)
Olivier Beaudoux, Arnaud Blouin, Olivier Barais, Jean-Marc Jézéquel. Specifying and implementing UI Data Bindings with Active Operations. ACM SIGCHI Symposium on Engineering Interactive Computing Systems, Jun 2011, Pise, Italy. pp.127--136, ⟨10.1145/1996461.1996506⟩. ⟨inria-00590896⟩
304 Consultations
233 Téléchargements
