Two-Component Horizontal Motion Vectors from Scanning Eye-Safe Aerosol Lidar
Derive the two-component vector motion field from pairs of aerosol backscatter lidar images and compare results with observations from a co-located sonic anemometer. Two methods will be tested: correlations and dense estimation.
