Multi-compartment models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2007
We consider models with a general structure which, for example, encompasses the so-called DI, SP or DISP models with mass action incidence. We give a very simple formule for the basic reproduction ratio R0. If R0 \leq 1, we prove that the disease free equilibrium is globally asymptotically stable on the nonnegative orthant. If R0 > 1, we prove the existence of a unique endemic equilibrium in the positive orthant and give an explicit formula. We prove the global asymptotic stability of the endemic equilibrium, when R0 > 1 for SP model.
DCDS07supl.pdf (412.34 Ko) Télécharger le fichier
inria-00591683 , version 1 (09-05-2011)
  • HAL Id : inria-00591683 , version 1
Abderrahman Iggidr, Joseph Mbang, Gauthier Sallet, Jean-Jules Tewa. Multi-compartment models. Discrete and Continuous Dynamical Systems - Series S, 2007, Dynamical Systems and Differential Equations. Proceedings of the 6th AIMS International Conference., 2007 (Special), pp.506-519. ⟨inria-00591683⟩
461 Consultations
707 Téléchargements
