Value Joins are Expensive over (Probabilistic) XML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Evgeny Kharlamov
  • Fonction : Auteur
  • PersonId : 882894
Werner Nutt
  • Fonction : Auteur
  • PersonId : 882895
Pierre Senellart
We address the cost of adding value joins to tree-pattern queries and monadic second-order queries over trees in terms of the tractability of query evaluation over two data models: XML and probabilistic XML. Our results show that the data complexity rises from linear, for join-free queries, to intractable, for queries with value joins, while combined complexity remains essentially the same. For tree-pattern queries with joins (TPJ) the complexity jump is only on probabilistic XML, while for monadic second-order logic over trees with joins (TMSOJ) it already appears for deterministic XML documents. Moreover, for TPJ queries that have a single join, we show a dichotomy: every query is either essentially join-free, and in this case it is tractable over probabilistic XML, or it is intractable. In this light we study the problem of deciding whether a query with joins is essentially join-free. For TMSOJ we prove that this problem is undecidable and for TPJ it is $\Pi_P^2$-complete. Finally, for TPJ we provide a conceptually simple criterion to check whether a given query is essentially join free.
main.pdf (229.78 Ko) Télécharger le fichier
inria-00591905 , version 1 (10-05-2011)
  • HAL Id : inria-00591905 , version 1
Evgeny Kharlamov, Werner Nutt, Pierre Senellart. Value Joins are Expensive over (Probabilistic) XML. EDBT Workshop: The Logic in Databases, Mar 2011, Uppsala, Sweden. ⟨inria-00591905⟩
58 Consultations
131 Téléchargements
