Two results concerning chirps and 2-microlocal exponents prescription - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied and Computational Harmonic Analysis Année : 1998
The local behavior of a function near a Hölder singularity located at a point x_0 can be finely described by means of its 2-microlocal domain. We solve the issue of prescribing this domain. A more compact description can be given using two parameters, the Hölder exponent and the chirp exponent. We give a necessary condition satisfied by this couple of exponents considered as functions of x_0.
Two_results_concerning_chirps_and_2-microlocal_exponents_prescription.pdf (2.91 Mo) Télécharger le fichier
inria-00593247 , version 1 (13-05-2011)
Bertrand Guilheneuf, Stéphane Jaffard, Jacques Lévy Véhel. Two results concerning chirps and 2-microlocal exponents prescription. Applied and Computational Harmonic Analysis, 1998, 5 (4), pp.487-492. ⟨10.1006/acha.1997.0241⟩. ⟨inria-00593247⟩
102 Consultations
92 Téléchargements
