s'authentifier
version française rss feed
inria-00593567, version 1
Perceptive self-organizing maps based on the coupling of neural fields with the BCM learning rule for multi modal association
Mathieu Lefort () 1, Yann Boniface () a1, Bernard Girau () 1
Résumé : To move in a complex and changing environment, according to the active perception theory, an agent needs to learn the multi modal correlations between its actions and the changes they induce in the environment . Human beings interact with their environment through several distant organs, whose sensory flow processing are influencing on each others as, for example, in the Mc Gurk effect. In the functional view of the cortex, each sensory area processes a specific sensory flow and associative areas integrate these flows in a consistent representation of the world that influences in return uni modal perceptions as for the ventriloquist effect. At a mesoscopic level, the cortex shows a generic structure composed of multi layers cortical columns. We propose a bio inspired model of perceptive map which, using a continuous and unsupervised learning, self-organizes to map a sensory data flow. Thus, using a spatial competition mechanism, a perceptive map provides an activity bump representing the current perception. In a multi modal architecture, by connecting multiple perceptive maps to an associative map with reciprocal spatially constrained connectivity, the spatial localization of each perception have to relax the multi modal constraints.
  • a –  INRIA
  • 1 :  CORTEX (INRIA Lorraine - LORIA)
  • INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
  • Domaine : Sciences cognitives/Neurosciences
  • inria-00593567, version 1
  • oai:hal.inria.fr:inria-00593567
  • Contributeur :
  • Soumis le : Lundi 16 Mai 2011, 15:35:34
  • Dernière modification le : Jeudi 19 Mai 2011, 10:00:22
tous les articles de la base du CCSd...
