inria-00593738, version 4
Formal proofs in real algebraic geometry: from ordered fields to quantifier elimination
Cyril Cohen
a, 1, 2, 3Assia Mahboubi
1, 2, 3
Logical Methods in Computer Science 8, 1:02 (2012) 1-40
Résumé : This paper describes a formalization of discrete real closed fields in the Coq proof assistant. This abstract structure captures for instance the theory of real algebraic numbers, a decidable subset of real numbers with good algorithmic properties. The theory of real algebraic numbers and more generally of semi-algebraic varieties is at the core of a number of effective methods in real analysis, including decision procedures for non linear arithmetic or optimization methods for real valued functions. After defining an abstract structure of discrete real closed field and the elementary theory of real roots of polynomials, we describe the formalization of an algebraic proof of quantifier elimination based on pseudo-remainder sequences following the standard computer algebra literature on the topic. This formalization covers a large part of the theory which underlies the efficient algorithms implemented in practice in computer algebra. The success of this work paves the way for formal certification of these efficient methods.
- a – INRIA
- 1 : Microsoft Research - Inria Joint Centre (MSR - INRIA)
- INRIA – Microsoft – Microsoft Research Laboratory Cambridge
- 2 : TypiCal (INRIA Saclay - Ile de France)
- INRIA – CNRS : UMR – Polytechnique - X
- 3 : Laboratoire d'informatique de l'école polytechnique (LIX)
- CNRS : UMR7161 – Polytechnique - X
- Domaine : Informatique/Logique en informatique
- Mots-clés : Formal proofs – Coq – quantifier elimination – small scale reflection – real algebraic geometry – real closed fields
- Versions disponibles : v1 (17-05-2011) v2 (05-12-2011) v3 (17-01-2012) v4 (17-02-2012)
- inria-00593738, version 4
- http://hal.inria.fr/inria-00593738
- oai:hal.inria.fr:inria-00593738
- Contributeur : Cyril Cohen
- Soumis le : Jeudi 16 Février 2012, 14:19:27
- Dernière modification le : Vendredi 17 Février 2012, 10:46:09
Documents associés
Exporter
