Energy-Aware Ant Colony Based Workload Placement in Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Louis Rilling
  • Fonction : Auteur
  • PersonId : 879795
With cloud computing becoming ubiquitous, cloud providers are starting to deploy increasing numbers of energy hungry data centers. Energy conservation then becomes essential, in order to decrease operation costs and increase the system reliability. One traditional approach to conserve energy in these environments is to perform workload (i.e., VM) consolidation. Thereby, workload is packed on the least number of physical machines in order to increase the resource utilization and thus be able to transition parts of the resources into a lower power state. However, most of the workload consolidation approaches applied until now are limited to a single resource (e.g., CPU) and rely on relatively simple greedy algorithms such as First-Fit Decreasing (FFD), which perform resource-dissipative workload placement. In this work, we model the workload placement problem as an instance of the multi-dimensional bin-packing (MDBP) problem and design a novel, nature-inspired algorithm based on the Ant Colony Optimization (ACO) meta-heuristic to compute the placement dynamically, according to the current load. We evaluate the ACO-based approach by comparing it with one frequently applied greedy algorithm (i.e., FFD). Our simulation results demonstrate that ACO outperforms the evaluated greedy approach as it achieves superior energy gains through better server utilization and requires less machines.
Avec le succès des services Cloud, les fournisseurs de ces services déploient de plus en plus de centres de données gourmands en énergie. Pour réduire les coûts et augmenter la fiabilité du système, économiser l'énergie devient essentiel. Une approche courante pour économiser de l'énergie dans ces environnements consiste à grouper les charges de travail (c'est-à-dire à grouper les machines virtuelles). Ainsi, la charge de travail est regroupée sur le plus petit nombre de machines physiques possible pour maximiser l'usage de ce sous-ensemble des ressources, et pouvoir ainsi mettre les autres ressources qui sont sous-utilisées en mode d'économie d'énergie. Cependant, jusqu'à présent, la plupart des approches fondées sur le regroupement des charges de travail se limitent à la prise en compte d'un seul type de ressource (par exemple, le processeur) et reposent sur des algorithmes gloutons relativement simples tel que le First-Fit Decreasing (FDD), qui gaspillent les ressources. Dans cet article, nous modélisons le problème du placement de charges de travail en tant qu'une instance du problème de bin-packing multi-dimensionnel, et nous construisons un nouvel algorithme bio-inspiré utilisant une méta heuristique d'optimisation inspirée des colonies de fourmis (Ant Colony Optimization, ACO) qui calcule les placements dynamiquement en fonction de la charge courante. Nous évaluons l'algorithme ACO en le comparant à l'algorithme glouton traditionnel (l'algorithme FDD). Les résultats de simulation montrent que l'algorithme ACO surpasse l'approche gloutonne en améliorant le gain d'énergie par une meilleure utilisation des serveurs et en exigeant moins de machines.
RR-7622.pdf (449.22 Ko) Télécharger le fichier
inria-00594992 , version 1 (23-05-2011)
  • HAL Id : inria-00594992 , version 1
Eugen Feller, Louis Rilling, Christine Morin. Energy-Aware Ant Colony Based Workload Placement in Clouds. [Research Report] RR-7622, INRIA. 2011. ⟨inria-00594992⟩
432 Consultations
1286 Téléchargements
