Usage Analysis & Demonstrators - Version 2.0
This second version of the "Usage Analysis and Demonstrators " document mainly presents four case studies done during the second part of the SCOrWare project: ● (Task 3.1) Component and service-oriented architecture in the Scientific Software field (improvements of works done during the first year) ● (Task 3.2) SCA as a SOA design methodology in the domain of CDE (Collaborative Development Environment). Following the withdraw of one of the partners (eXo Platform, provider of an open-source portal solution) during the first year, some changes have been decided during the second part of the project and an alternative demonstrator has been designed. ● (Task 3.3) How SCA contributes to reusing and enriching software components. Following the first year project's review, this scenario has been reinforced, and is the major demonstrator for the SCOrWare platform in the field of enterprise business applications. ● (Task 3.5) Using the SCOrWare platform and a component-oriented architecture in the context of a network monitoring system. A new partner (Thales Communications, in collaboration with Open Wide and EBM Websourcing) has joined the SCOrWare consortium during the second part of the project, following the withdraw of Amadeus.
Génie logiciel [cs.SE]
