s'authentifier
version française rss feed
inria-00596150, version 1
Diffuse noise robust multiple source localization based on noise reduction in covariance matrix domain
Nobutaka Ito a12, Emmanuel Vincent () 1, Nobutaka Ono () 2, Rémi Gribonval () b1, Shigeki Sagayama () 2
IEICE EA Technical Committee Meeting 110 (2010) 31-36
Résumé : In this paper, we propose a method for estimating the azimuths of multiple sound sources accurately even in the presence of diffuse noise. MUSIC (MUltiple SIgnal Classification) for the estimation of the azimuths of multiple sources is robust against spatially white noise but the estimation performance degrades in the presence of diffuse noise. Based on a low-rank assumption on the covariance matrix of directional signals and the assumption that the covariance matrix of diffuse noise belongs to a subspace in a matrix space, the proposed method estimates the covariance matrix of the directional signals and applies MUSIC to the estimated matrix. The subspace model on the covariance matrix of diffuse noise includes as special cases noise models such as spatially uncorrelated noise, noise with a given coherence matrix, and isotropic noise observed with a crystal array. We showed through experiments with real-world noise recordings that the proposed method estimated the azimuths of multiple sources more accurately than the conventional MUSIC.
  • Domaine : Informatique/Traitement du signal et de l'image
    Sciences de l'ingénieur/Traitement du signal et de l'image
  • inria-00596150, version 1
  • oai:hal.inria.fr:inria-00596150
  • Contributeur :
  • Soumis le : Vendredi 30 Septembre 2011, 12:25:57
  • Dernière modification le : Vendredi 30 Septembre 2011, 15:33:53
tous les articles de la base du CCSd...
