Gröbner bases of bihomogeneous ideals generated by polynomials of bidegree (1,1): Algorithms and complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2011
Solving multihomogeneous systems, as a wide range of \emph{structured algebraic systems} occurring frequently in practical problems, is of first importance. Experimentally, solving these systems with Gröbner bases algorithms seems to be easier than solving homogeneous systems of the same degree. Nevertheless, the reasons of this behaviour are not clear. In this paper, we focus on bilinear systems (i.e. bihomogeneous systems where all equations have bidegree $(1,1)$). Our goal is to provide a theoretical explanation of the aforementioned experimental behaviour and to propose new techniques to speed up the Gröbner basis computations by using the multihomogeneous structure of those systems. The contributions are theoretical and practical. First, we adapt the classical $F_5$ criterion to avoid reductions to zero which occur when the input is a set of bilinear polynomials. We also prove an explicit form of the Hilbert series of bihomogeneous ideals generated by generic bilinear polynomials and give a new upper bound on the degree of regularity of generic affine bilinear systems. We propose also a variant of the $F_5$ Algorithm dedicated to multihomogeneous systems which exploits a structural property of the Macaulay matrix which occurs on such inputs. Experimental results show that this variant requires less time and memory than the classical homogeneous $F_5$ Algorithm. Lastly, we investigate the complexity of computing a Gröbner basis for the grevlex ordering of a generic $0$-dimensional affine bilinear system over $k[x_1,\ldots, x_{n_x}, y_1,\ldots, y_{n_y}]$. In particular, we show that this complexity is upper bounded by $O\left({{n_x+n_y+\min(n_x+1,n_y+1)}\choose{\min(n_x+1,n_y+1)}}^\omega\right)$, which is polynomial in $n_x+n_y$ (i.e. the number of unknowns) when $\min(n_x,n_y)$ is constant.
JSC_FSS10.pdf (279.98 Ko) Télécharger le fichier
inria-00596631 , version 1 (30-05-2011)
Jean-Charles Faugère, Mohab Safey El Din, Pierre-Jean Spaenlehauer. Gröbner bases of bihomogeneous ideals generated by polynomials of bidegree (1,1): Algorithms and complexity. Journal of Symbolic Computation, 2011, 46 (4), pp.406-437. ⟨10.1016/j.jsc.2010.10.014⟩. ⟨inria-00596631⟩
246 Consultations
1545 Téléchargements
