Towards Consistency Management for a Business-Driven Development of SOA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Karim Dahman
  • Fonction : Auteur
  • PersonId : 880821
François Charoy
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
The usage of the Service Oriented Architecture (SOA) along with the Business Process Management has emerged as a valuable solution for the complex (business process driven) system engineering. With a Model Driven Engineering where the business process models drive the supporting service component architectures, less effort is gone into the Business/IT alignment during the initial development activities, and the IT developers can rapidly proceed with the SOA implementation. However, the difference between the design principles of the emerging domain-specific languages imposes serious challenges in the following re-design phases. Moreover, enabling evolutions on the business process models while keeping them synchronized with the underlying software architecture models is of high relevance to the key elements of any Business Driven Development (BDD). Given a business process update, this paper introduces an incremental model transformation approach that propagates this update to the related service component configurations. It, therefore, supports the change propagation among heterogenous domain-specific languages, e.g., the BPMN and the SCA. As a major contribution, our approach makes model transformation more tractable to reconfigure system architecture without disrupting its structural consistency. We propose a synchronizer that provides the BPMN-to-SCA model synchronization with the help of the conditional graph rewriting.
Towards_Consistency_Management.pdf (415.28 Ko) Télécharger le fichier
inria-00597067 , version 1 (10-06-2011)
  • HAL Id : inria-00597067 , version 1
Karim Dahman, François Charoy, Claude Godart. Towards Consistency Management for a Business-Driven Development of SOA. The 15th IEEE International Enterprise Distributed Object Computing Conference (EDOC'11), Aug 2011, Helsinki, Finland. ⟨inria-00597067⟩
196 Consultations
191 Téléchargements
