s'authentifier
version française rss feed
inria-00597576, version 2
Parallel Spherical Harmonic Transforms on heterogeneous architectures (GPUs/multi-core CPUs)
Mikolaj Szydlarski (Auteur à contacter de préférence) 1, Pierre Esterie (Auteur à contacter de préférence) 2, Joel Falcou () a2, Laura Grigori () 1, R. Stompor (Auteur à contacter de préférence) b3
N° RR-7635 (2012)
Résumé : Spherical Harmonic Transforms (SHT) are at the heart of many scientific and practical applications ranging from climate modelling to cosmological observations. In many of these areas new, cutting-edge science goals have been recently proposed requiring simulations and analyses of experimental or observational data at very high resolutions and of unprecedented volumes. Both these aspects pose formidable challenge for the currently existing implementations of the transforms. This paper describes parallel algorithms for computing the SHTs with two variants of intra-node parallelism appropriate for novel supercomputer architectures, multi-core processors and Graphic Processing Units (GPU) and discusses their performance tests, alone and embedded within a top-level, MPI-based parallelization layer ported from the S$^2$HAT library, in terms of their accuracy, overall efficiency and scalability. We show that our inverse SHTs with GeForce 400 Series GPUs equipped with latest CUDA architecture ("Fermi") outperforms the state of the art implementation for a multi-core processor executed on a current Intel Core i7-2600K. Furthermore, we show that an MPI/CUDA version of the inverse transform run on a cluster of 128 NVIDIA Tesla S1070 is as much as 3 times faster than the hybrid MPI/OpenMP version executed on the same number of quad-core processors Intel Nahalem for problem sizes motivated by our target applications. For the direct transforms, the performance is however found to be at the best comparable. Here we discuss in detail optimizations of two major steps involved in the transforms calculation, demonstrating how the overall performance efficiency can be obtained, and elucidating the sources of the dichotomy between the direct and the inverse operations
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
    Physique/Astrophysique/Cosmologie et astrophysique extra-galactique
    Planète et Univers/Astrophysique/Cosmologie et astrophysique extra-galactique
    Physique/Physique/Physique Atmosphérique et Océanique
    Physique/Physique/Géophysique
    Planète et Univers/Sciences de la Terre/Géophysique
    Sciences de l'environnement/Milieux et Changements globaux
  • Mots-clés : Spherical Harmonic Transforms – hybrid architectures – hybrid programming – OpenMP – CUDA – Multi-GPU – CMB
  • Référence interne : RR-7635
  • Versions disponibles :  v1 (01-06-2011) v2 (05-06-2012)
  • inria-00597576, version 2
  • oai:hal.inria.fr:inria-00597576
  • Contributeur :
  • Soumis le : Mercredi 30 Mai 2012, 11:55:52
  • Dernière modification le : Vendredi 8 Juin 2012, 17:10:07
tous les articles de la base du CCSd...
