2-Microlocal Analysis and Application in Signal Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
This paper introduces the use of 2-microlocal analysis in signal processing. 2-microlocal analysis is a powerful tool for studying the regularity of solutions of partial differential equations. It allows to track the evolution of the Hölder exponent under the action of pseudo-differential operators. We first prove theoretical results pertaining to the so-called 2-microlocal frontier, that allow to characterize and prescribe it at a given point. We then show how to combine 2-microlocal analysis with multifractal analysis in order to perform image denoising.
2-Microlocal_Analysis_and_Application_in_Signal_Processing.pdf (10.89 Mo) Télécharger le fichier
inria-00598752 , version 1 (07-06-2011)
  • HAL Id : inria-00598752 , version 1
Bertrand Guiheneuf, Jacques Lévy Véhel. 2-Microlocal Analysis and Application in Signal Processing. International Wavelet Conference, Apr 1998, Tanger, Morocco. ⟨inria-00598752⟩
Collections
INRIA INSMI INRIA2
166 Consultations
51 Téléchargements
