Software architecture for an exploration robot based on Urbi - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present the software architecture of a mobile robot whose goal is to autonomously explore an unknown indoor environment and to build a semantic map containing high-level information. This robot was developed under the Panoramic and Active Camera for Object Mapping (PACOM) project whose goal is to participate in the French exploration and mapping contest CAROTTE. The software architecture puts together a large set of soft- ware components that deals with mapping, planning, object recognition and exploration. This architecture is based on the Urbi framework. We present the main functionalities of Urbi that were used for this project and show in detail how these capabilities make it possible to integrate all these modules.
Baillie-Software-archi.PDF (1000.69 Ko) Télécharger le fichier
inria-00599674 , version 1 (10-06-2011)
  • HAL Id : inria-00599674 , version 1
Jean-Christophe Baillie, Akim Demaille, Guillaume Duceux, David Filliat, Quentin Hocquet, et al.. Software architecture for an exploration robot based on Urbi. 6th National Conference on Control Architectures of Robots, INRIA Grenoble Rhône-Alpes, May 2011, Grenoble, France. 12 p. ⟨inria-00599674⟩
Collections
ENSTA CAR-2011
271 Consultations
206 Téléchargements
