Lp Centroidal Voronoi Tesselation and its applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2010
Bruno Lévy
Yang Liu
  • Fonction : Auteur
This paper introduces Lp -Centroidal Voronoi Tessellation (Lp -CVT), a generalization of CVT that minimizes a higher-order moment of the coordinates on the Voronoi cells. This generalization allows for aligning the axes of the Voronoi cells with a predefined background tensor field (anisotropy). Lp -CVT is computed by a quasi-Newton optimization framework, based on closed-form derivations of the objective function and its gradient. The derivations are given for both surface meshing (Ω is a triangulated mesh with per-facet anisotropy) and volume meshing (Ω is the interior of a closed triangulated mesh with a 3D anisotropy field). Applications to anisotropic, quad-dominant surface remeshing and to hex-dominant volume meshing are presented. Unlike previous work, Lp -CVT captures sharp features and intersections without requiring any pre-tagging.
LpCVT.pdf (16.46 Mo) Télécharger le fichier
inria-00600251 , version 1 (14-06-2011)
Bruno Lévy, Yang Liu. Lp Centroidal Voronoi Tesselation and its applications. ACM Transactions on Graphics, 2010, Proceedings of ACM SIGGRAPH 2010, 29 (4), ⟨10.1145/1833349.1778856⟩. ⟨inria-00600251⟩
948 Consultations
789 Téléchargements
