Incidence simplicial matrices formalized in Coq/SSReflect - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Lecture Notes in Artificial Intelligence Année : 2011
Jónathan Heras
  • Fonction : Auteur
  • PersonId : 904378
María Poza
  • Fonction : Auteur
  • PersonId : 904379
Maxime Denes
  • Fonction : Auteur
  • PersonId : 904380
Laurence Rideau
Simplicial complexes are at the heart of Computational Algebraic Topology, since they give a concrete, combinatorial description of otherwise rather abstract objects which makes many important topological computations possible. The whole theory has many applications such as coding theory, robotics or digital image analysis. In this paper we present a formalization in the COQ theorem prover of simplicial complexes and their incidence matrices as well as the main theorem that gives meaning to the definition of homology groups and is a first step towards their computation.
Autre [cs.OH]
ismfis.pdf (146.93 Ko) Télécharger le fichier
inria-00603208 , version 1 (24-06-2011)
Jónathan Heras, María Poza, Maxime Denes, Laurence Rideau. Incidence simplicial matrices formalized in Coq/SSReflect. Conference on Intelligent Computer Mathematics, Jul 2011, Bertinoro, Italy. ⟨10.1007/978-3-642-22673-1_3⟩. ⟨inria-00603208⟩
Collections
INRIA INRIA2
200 Consultations
377 Téléchargements
