A Generic Formalised Framework for Reasoning About Weak Memory Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
This paper describes Coq libraries devoted to the semantic of relaxed memory models. These libraries formalise a framework which covers a large class of industrial models. Implementing this framework inside a proof assistant has significantly helped improving its design and crafting the most concise and relevant specifications. Similarly the use of a proof assistant has been instrumental in the study of the semantic of synchronisation primitives, which we illustrate by the formal proof of a barrier placement theorem. We explain the choices we made to re-design our Coq libraries, and in particular what we gained from adopting a small-scale reflection methodology.
itp.pdf (189.22 Ko) Télécharger le fichier
inria-00604656 , version 1 (29-06-2011)
  • HAL Id : inria-00604656 , version 1
Jade Alglave, Assia Mahboubi. A Generic Formalised Framework for Reasoning About Weak Memory Models. 2011. ⟨inria-00604656⟩
274 Consultations
161 Téléchargements
