Stepwise Development of Distributed Algorithms (Research Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Abstract. We study distributed algorithms using the "correct-by-construction process", which involves the Event B method and the refinement process. These algorithms integrate non-functional requirements like probabilistic aspects. Therefore, it appears that the correct-by-construction process should integrate probabilistic arguments to be considered as a development and verification framework for distributed algorithms. We present here preliminary elements of a global approach on how to take into account probabilistic arguments during the development of distributed algorithms, and we illustrate this approach with the study of distributed coloring algorithms.
_ANDRIAMIARINA_Abstract_FME_Symposium_FM2011_v4.pdf (193.53 Ko) Télécharger le fichier
inria-00606204 , version 1 (05-07-2011)
  • HAL Id : inria-00606204 , version 1
Manamiary Bruno Andriamiarina. Stepwise Development of Distributed Algorithms (Research Abstract). 2011. ⟨inria-00606204⟩
136 Consultations
169 Téléchargements
