Stepwise Development Of Distributed Vertex Coloring Algorithms (Full Report) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2011
Software-based systems have a strong impact in the daily life. For instance, systems like televisions, cell phones, credit cards are used for persons, while others systems, like networks, telecommunications, distributed and embedded devices, supercomputers, are used by organisations such as companies, governments, nations... Several countries, especially the advanced ones, rely on systems for the efficiency of domains like economy, health... Since they are needed in daily life, those systems should be reliable, and their specifications and design must be clear, understandable and should follow specific rules and they must avoid faults, failures and if they can not, they should at least be fault-tolerant and fail-safe. Therefore, because of those requirements, "Formal Verification" can be usefull to obtain an assurance and guarantee of their correctness with respect to safety and security issues.
Rapport_v0.pdf (6.68 Mo) Télécharger le fichier
inria-00606254 , version 1 (05-07-2011)
inria-00606254 , version 2 (20-11-2014)
  • HAL Id : inria-00606254 , version 2
Manamiary Bruno Andriamiarina, Dominique Méry. Stepwise Development Of Distributed Vertex Coloring Algorithms (Full Report). [Technical Report] LORIA - Université de Lorraine. 2011, pp.90. ⟨inria-00606254v2⟩
169 Consultations
185 Téléchargements
