Enhancing and Optimizing the Render Cache - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Interactive rendering often requires the use of simplified shading algorithms with reduced illumination fidelity. Higher quality rendering algorithms are usually too slow for interactive use. The render cache is a technique to bridge this performance gap and allow ray-based renderers to be used in interactive contexts by providing automatic sample interpolation, frame-to-frame sample reuse, and prioritized sampling. In this paper we present several extensions to the original render cache including predictive sampling, reorganized computation for better memory coherence, an additional interpolation filter to handle sparser data, and SIMD acceleration. These optimizations allow the render cache to scale to larger resolutions, reduce its visual artifacts, and provide better handling of low sample rates. We also provide a downloadable binary to allow researchers to evaluate and use the render cache.
walter_b_electronic.pdf (1.7 Mo) Télécharger le fichier
walter_b_1.pdf (1.69 Mo) Télécharger le fichier
walter_b_colorpage.pdf (1.63 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00606729 , version 1 (22-07-2011)
  • HAL Id : inria-00606729 , version 1
Bruce Walter, George Drettakis, Donald P. Greenberg. Enhancing and Optimizing the Render Cache. Proceedings of the Eurographics Workshop on Rendering, Eurographics, Jun 2002, Pise, Italy. pp.37-42. ⟨inria-00606729⟩
270 Consultations
220 Téléchargements
