An Interactive Perceptual Rendering Pipeline using Contrast and Spatial Masking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present a new perceptual rendering pipeline which takes into account visual masking due to contrast and spatial frequency. Our framework predicts inter-object, scene-level masking caused by partial occlusion and shadows. It is designed for interactive applications and runs efficiently on the GPU. This is achieved using a layer-based approach together with an efficient GPU-based computation of threshold maps. We build upon this prediction framework to introduce a perceptually-based level of detail control algorithm. We conducted a perceptual user study which indicates that our perceptual pipeline generates results which are consistent with what the user perceives. Our results demonstrate significant quality improvement for scenes with masking due to frequencies and contrast, such as masking due to trees or foliage, or due to high-frequency shadows.
Mots clés
thresholdmaps.pdf (6.16 Mo) Télécharger le fichier
DBDLSV07.avi (72.96 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00606796 , version 1 (19-07-2011)
George Drettakis, Nicolas Bonneel, Carsten Dachsbacher, Sylvain Lefebvre, Michael Schwarz, et al.. An Interactive Perceptual Rendering Pipeline using Contrast and Spatial Masking. Eurographics Symposium on Rendering Techniques, Eurographics, Jun 2007, Grenoble, France. pp.297-308, ⟨10.2312/EGWR/EGSR07/297-308⟩. ⟨inria-00606796⟩
348 Consultations
171 Téléchargements
