Relighting Photographs of Tree Canopies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2011
We present an image-based approach to relighting photographs of tree canopies. Our goal is to minimize capture overhead; thus the only input required is a set of photographs of the tree taken at a single time of day, while allowing relighting at any other time. We first analyze lighting in a tree canopy both theoretically and using simulations. From this analysis, we observe that tree canopy lighting is similar to volumetric illumination. We assume a single-scattering volumetric lighting model for tree canopies, and diffuse leaf reflectance; we validate our assumptions with synthetic renderings. We create a volumetric representation of the tree from 10-12 images taken at a single time of day and and use a single-scattering participating media lighting model. An analytical sun and sky illumination model provides consistent representation of lighting for the captured input and unknown target times. We relight the input image by applying a ratio of the target and input time lighting representations. We compute this representation efficiently by simultaneously coding transmittance from the sky and to the eye in spherical harmonics. We validate our method by relighting images of synthetic trees and comparing to path-traced solutions. We also present results for photographs where sparse, validating with time-lapse ground truth sequences.
paper.pdf (19.61 Mo) Télécharger le fichier
thesis-appendix.pdf (66.31 Mo) Télécharger le fichier
treeRelight_final.mov (29.9 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Vidéo
inria-00607042 , version 1 (07-07-2011)
Marcio Cabral, Nicolas Bonneel, Sylvain Lefebvre, George Drettakis. Relighting Photographs of Tree Canopies. IEEE Transactions on Visualization and Computer Graphics, 2011, ⟨10.1109/TVCG.2010.236⟩. ⟨inria-00607042⟩
206 Consultations
142 Téléchargements
