Adaptive-based Distributed Cooperative Multi-Robot Coverage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present a solution to the problem of positioning a team of mobile robots for a surveillance task in a non-convex environment with unknown obstacles. The problem is addressed taking into account several physical and environmental constraints like limited sensor capabilities, obstacle-avoidance, etc. The goal is to maximize the area monitored by the team, by identifying the best configuration of the team members. Due to the non-convex nature of the problem, an analytical solution cannot be obtained. The proposed method is based on a new cognitive-based, adaptive optimization algorithm (CAO). This method allows getting coordinated and scalable controls to accomplish the task. Furthermore, we propose a different formulation of the problem in order to obtain a distributed solution which allows us to consider also limited communication capabilities. Extensive simulations are presented to evaluate the efficiency of the proposed algorithm and to compare centralized and distributed approach.
accFinal.pdf (502.17 Ko) Télécharger le fichier
inria-00607085 , version 1 (07-07-2011)
  • HAL Id : inria-00607085 , version 1
Alessandro Renzaglia, Lefteris Doitsidis, Agostino Martinelli, Elias Kosmatopoulos. Adaptive-based Distributed Cooperative Multi-Robot Coverage. American Control Conference 2011, Jul 2011, San Francisco, United States. ⟨inria-00607085⟩
146 Consultations
302 Téléchargements
