Characteristics of Invariant Weights Related to Code Equivalence over Rings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cathy Mc Fadden
  • Fonction : Auteur
  • PersonId : 905315
Marcus Greferath
  • Fonction : Auteur
  • PersonId : 905316
Jens Zumbragel
  • Fonction : Auteur
  • PersonId : 905317
The Extension Theorem states that, for a given weight on he alphabet, every linear isometry between linear codes extends to a mono- mial transformation of the entire space. This theorem has been proved for several weights and alphabets, including the original MacWilliams' Equivalence Theorem for Hamming weight on codes over nite elds. Now we ask: What conditions must a weight satisfy so that the Extension Theorem will hold? In this paper we provide an algebraic framework for determining such conditions, generalising the approach taken in [5].
137.pdf (120.49 Ko) Télécharger le fichier
inria-00607730 , version 1 (11-07-2011)
  • HAL Id : inria-00607730 , version 1
Cathy Mc Fadden, Marcus Greferath, Jens Zumbragel. Characteristics of Invariant Weights Related to Code Equivalence over Rings. WCC 2011 - Workshop on coding and cryptography, Apr 2011, Paris, France. pp.91-100. ⟨inria-00607730⟩
Collections
WCC2011 TDS-MACS
144 Consultations
256 Téléchargements
