Domain-driven Probabilistic Analysis of Programmable Logic Controllers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Programmable Logic Controllers are widely used in industry. Reliable PLCs are vital to many critical applications. This paper presents a novel symbolic approach for analysis of PLC systems. The main components of the approach consists of: (1) calculating the uncertainty characterization of the PLC systems, (2) abstracting the PLC system as a Hidden Markov Model, (3) solving the Hidden Markov Model using domain knowledge, (4) integrating the solved Hidden Markov Model and the uncertainty characterization to form an integrated (regular) Markov Model, and (5) harnessing probabilistic model checking to analyze properties on the resultant Markov Model. The framework provides expected performance measures of the PLC systems by automated analytical means without expensive simulations. Case studies on an industrial automated system are performed to demonstrate the effectiveness of our approach.
Domain_driven_Probabilistic_Analysis_of_Programmable_Logic_Controllers.pdf (465.25 Ko) Télécharger le fichier
inria-00612414 , version 1 (10-08-2011)
  • HAL Id : inria-00612414 , version 1
Hehua Zhang, Yu Jiang, Hung William N.N., Xiaoyu Song, Ming Gu. Domain-driven Probabilistic Analysis of Programmable Logic Controllers. 13th International Conference on Formal Engineering Methods(ICFEM 2011), Oct 2011, Durham, United Kingdom. ⟨inria-00612414⟩
173 Consultations
252 Téléchargements
