Multifractals, Texture, and Image Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1992
Jacques Lévy-Vehel
  • Fonction : Auteur
  • PersonId : 902488
Pascal Mignot
  • Fonction : Auteur
Jean-Paul Berroir
  • Fonction : Auteur
  • PersonId : 833604
Image analysis using texture and multifractal paradigms is addressed. Multifractal theory and its application to image description are discussed, and it is shown that this approach allows the discrete signal to be worked on directly. A system for texture classification that is based on a learning scheme and does not make use of any a priori model is introduced. Image segmentation is then considered, and the notion of mixed classes, which allows accurate detection of texture boundaries on complex images, is introduced.
Fichier non déposé
inria-00613979 , version 1 (08-08-2011)
Jacques Lévy-Vehel, Pascal Mignot, Jean-Paul Berroir. Multifractals, Texture, and Image Analysis. CVPR'92 - IEEE Computer Society Conference on Computer Vision and Pattern Recognition, Jun 1992, Champaign, IL, United States. ⟨10.1109/CVPR.1992.223207⟩. ⟨inria-00613979⟩
Collections
INRIA INRIA2
50 Consultations
0 Téléchargements
