Three-dimensional Fire codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Igor Boyarinov
  • Fonction : Auteur
  • PersonId : 907491
Binary cyclic three-dimensional array codes that can correct three{dimensional bursts (or clusters ) of errors are considered. The class of binary cyclic three-dimensional burst-error-correcting array codes, called three-dimensional Fire codes, is constructed. Several important properties such as the burst-error-correcting capability and the positions of the parity-check symbols are presented. Also, encoding and decoding algorithms are given.
96.pdf (93.88 Ko) Télécharger le fichier
inria-00614377 , version 1 (11-08-2011)
  • HAL Id : inria-00614377 , version 1
Igor Boyarinov. Three-dimensional Fire codes. WCC 2011 - Workshop on coding and cryptography, Apr 2011, Paris, France. pp.323-330. ⟨inria-00614377⟩
Collections
WCC2011 TDS-MACS
55 Consultations
139 Téléchargements
