Some codes correcting single symmetric errors of limited magnitude - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Torleiv Kløve
  • Fonction : Auteur
  • PersonId : 907492
Jinquan Luo
  • Fonction : Auteur
  • PersonId : 907493
Somaye Yari
  • Fonction : Auteur
  • PersonId : 907494
An error model with symmetric errors of limited magnitude is considered. Limited magnitude means that the size of any error is limited by a number smaller (usually much smaller) than the alphabet size. Several constructions of codes correcting single error are given. In some cases, the codes are perfect or quasi-perfect.
38.pdf (118.21 Ko) Télécharger le fichier
inria-00614390 , version 1 (11-08-2011)
  • HAL Id : inria-00614390 , version 1
Torleiv Kløve, Jinquan Luo, Somaye Yari. Some codes correcting single symmetric errors of limited magnitude. WCC 2011 - Workshop on coding and cryptography, Apr 2011, Paris, France. pp.331-340. ⟨inria-00614390⟩
Collections
WCC2011 TDS-MACS
55 Consultations
134 Téléchargements
