Adaptive Scalable Layer Filtering Process For video scheduling over wireless networks based on MAC buffer management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, the problem of scalable video delivery over a time-varying wireless channel is considered. Packet scheduling and buffer management in both Application and Medium Access Control (MAC) layers are jointly considered. Various levels of knowledge of the state of the channel are considered. The control is performed via scalable layer filtering (some scalability layers may be dropped). In all cases, the problem is cast in the context of Markov Decision Processes which allows the design of foresighted policies maximizing some long-term reward. Without channel state observation, the control has to rely on the observation of the level of the MAC buffer only. Experimental results show that even with a lack of knowledge of the channel state, the foresighted control policy provides only a moderate loss in received video quality.
ICASSP_NC.pdf (105.02 Ko) Télécharger le fichier
inria-00614567 , version 1 (12-08-2011)
Nesrine Changuel, Nicholas Mastronarde, Mihaela van Der Schaar, Bessem Sayadi, Michel Kieffer. Adaptive Scalable Layer Filtering Process For video scheduling over wireless networks based on MAC buffer management. IEEE International Conference on Acoustics, Speech, and Signal Processing, May 2011, Prague, Czech Republic. pp.2352-2355, ⟨10.1109/ICASSP.2011.5946955⟩. ⟨inria-00614567⟩
114 Consultations
146 Téléchargements
