Efficient Retrieval and Ranking of Undesired Package Cycles in Large Software Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many design guidelines state that a software system architecture should avoid cycles between its packages. Yet such cycles appear again and again in many programs. We believe that the existing approaches for cycle detection are too coarse to assist the developers to remove cycles from their programs. In this paper, we describe an efficient algorithm that performs a fine-grained analysis of the cycles among the packages of an application. In addition, we define a metric to rank cycles by their level of undesirability, prioritizing the cycles that seems the more undesired by the developers. Our approach is validated on two large and mature software systems in Java and Smalltalk.
Fall11a-Tools2011-UndesirableCycles.pdf (495.25 Ko) Télécharger le fichier
inria-00614770 , version 1 (28-10-2011)
Jean-Rémy Falleri, Simon Denier, Jannik Laval, Philippe Vismara, Stéphane Ducasse. Efficient Retrieval and Ranking of Undesired Package Cycles in Large Software Systems. TOOLS, Jun 2011, Zurich, Switzerland. pp.260-275, ⟨10.1007/978-3-642-21952-8_19⟩. ⟨inria-00614770⟩
381 Consultations
167 Téléchargements
