Computing the Diameter of a Point Set
Given a finite set of points ¸al P in ℝd, the diameter of ¸al P is defined as the maximum distance between two points of ¸al P. We propose a very simple algorithm to compute the diameter of a finite set of points. Although the algorithm is not worst-case optimal, an extensive experimental study has shown that it is extremely fast for a large variety of point distributions. In addition, we propose a comparison with the recent approach of Har-Peled and derive hybrid algorithms to combine advantages of both approaches.
