Landmark-based registration using features identified through differential geometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2000
Registration of 3D medical images consists in computing the "best" transformation between two acquisitions, or equivalently, determines the point to point correspondence between the images. Registration algorithms are usually based either on features extracted from the image (feature-based approaches) or on the optimization of a similarity measure of the images intensities (intensitybased or iconic approaches). Another classification criterion is the type of transformation sought (e.g. rigid or non-rigid). In this chapter, we concentrate on feature-based approaches for rigid registration, similar approaches for non-rigid registration being reported in another set of publication [35, 36]. We show how to reduce the dimension of the registration problem by first extracting a surface from the 3D image, then landmark curves on this surface and possibly landmark points on these curves. This concept proved its efficiency through many applications in medical image analysis as we will see in the sequel. This work has been for a long time a central investigation topic of the Epidaure team [2] and we can only reflect here on a small part of the research done in this area. We present in the first section the notions of crest lines and extremal points and how these differential geometry features can be extracted from 3D images. In Section 2, we focus on the different rigid registration algorithms that we used to register such features. The last section analyzes the possible errors in this registration scheme and demonstrates that a very accurate registration could be achieved.
Pennec.HMIP.pdf (952.24 Ko) Télécharger le fichier
inria-00615106 , version 1 (17-08-2011)
  • HAL Id : inria-00615106 , version 1
Xavier Pennec, Nicholas Ayache, Jean-Philippe Thirion. Landmark-based registration using features identified through differential geometry. Bankman, I. Handbook of Medical Imaging - Processing and Analysis. I., Academic Press, pp.499--513, 2000. ⟨inria-00615106⟩
477 Consultations
565 Téléchargements
