A Robust and Efficient Block Matching Framework for Non Linear Registration of Thoracic CT Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The registration of thoracic images is a challenging problem with essential clinical applications such as radiotherapy and diagnosis. In the context of the EMPIRE10 challenge, we brie y introduce a general robust and e cient algorithm to register automatically any type of scalar images (CT, MRI, ...) on virtually any location (brain, thorax, ...). Although fully automatic and generic, the proposed algorithm reached the 17th place in the EMPIRE challenge over 34 algorithms evaluated. Moreover, we have since optimized further the parameter set used for the challenge and we demonstrate the ability of the algorithm to recover much better large displacements of the lungs boundaries.
Garcia_2010_EMPIRE10_2.pdf (269.74 Ko) Télécharger le fichier
inria-00616148 , version 1 (16-07-2013)
  • HAL Id : inria-00616148 , version 1
Vincent Garcia, Olivier Commowick, Grégoire Malandain. A Robust and Efficient Block Matching Framework for Non Linear Registration of Thoracic CT Images. Grand Challenges in Medical Image Analysis (MICCAI workshop), 2010, Beijing, China, China. pp.1-10. ⟨inria-00616148⟩
378 Consultations
243 Téléchargements
