A morphological and syntactic wide-coverage lexicon for Spanish: The Leffe - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we introduce the Le ́xico de Formas Flexionadas del Español (Leffe), a wide-coverage morphological and syntactic Spanish lexicon based on the Alexina lexical framework. We explain how the Leffe has been created by merging together several heterogeneous lexicons and how the Alexina lexical framework has been applied to Spanish. We also introduce a semi-automatic technique based on a tagger to detect the lexicon's deficiencies. A preliminary evaluation shows the potential of the Leffe and the relevance of both creation and extension processes.
ranlp09leffe.pdf (88.94 Ko) Télécharger le fichier
inria-00616693 , version 1 (08-02-2014)
  • HAL Id : inria-00616693 , version 1
Miguel A. Molinero, Benoît Sagot, Lionel Nicolas. A morphological and syntactic wide-coverage lexicon for Spanish: The Leffe. RANLP 2009 - Recent Advances in Natural Language Processing, Sep 2009, Borovets, Bulgaria. ⟨inria-00616693⟩
295 Consultations
273 Téléchargements
