DTW for Matching Radon Features: A Pattern Recognition and Retrieval Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a method for pattern such as graphical symbol and shape recognition and retrieval. It is basically based on dynamic programming for matching the Radon features. The key characteristic of the method is to use DTW algorithm to match corresponding pairs of histograms at every projecting angle. This allows to exploit the Radon property to include both boundary as internal structure of shapes, while avoiding compressing pattern representation into a single vector and thus miss information, thanks to the DTW. Experimental results show that the method is robust to distortion and degradation including affine transformations.
santosh_Acivs11.pdf (351.48 Ko) Télécharger le fichier
inria-00617287 , version 1 (26-08-2011)
Santosh K.C., Bart Lamiroy, Laurent Wendling. DTW for Matching Radon Features: A Pattern Recognition and Retrieval Method. Advanced Concepts for Intelligent Vision Systems, Aug 2011, Ghent, Belgium. pp.249--260, ⟨10.1007/978-3-642-23687-7_23⟩. ⟨inria-00617287⟩
210 Consultations
305 Téléchargements
