A Development Process for Requirements Based Service Choreography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marco Autili
  • Fonction : Auteur
  • PersonId : 854161
Davide Di Ruscio
  • Fonction : Auteur
  • PersonId : 863561
Paola Inverardi
  • Fonction : Auteur
  • PersonId : 875210
James Lockerbie
  • Fonction : Auteur
  • PersonId : 909479
Massimo Tivoli
  • Fonction : Auteur
  • PersonId : 861036
The Future Internet envisions a ubiquitous world where available services can be easily discovered and coordinated so to fit users' requirements and needs. Service choreographies will play a central role in this vision as an effective means to allow heterogeneous services to suitably collaborate. This paper describes our experience of choreography development within the CHOReOS project.
main.pdf (227.87 Ko) Télécharger le fichier
inria-00620917 , version 1 (09-09-2011)
  • HAL Id : inria-00620917 , version 1
Marco Autili, Davide Di Ruscio, Paola Inverardi, James Lockerbie, Massimo Tivoli. A Development Process for Requirements Based Service Choreography. Service-Oriented Computing: Consequences for Engineering Requirements Workshop co-located with the 19th IEEE International Requirements Engineering Conference, Aug 2011, Trento, Italy. ⟨inria-00620917⟩
Collections
CHOREOS
86 Consultations
197 Téléchargements
