DENOISING WITH GREEDY-LIKE PURSUIT ALGORITHMS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper provides theoretical guarantees for denoising per-formance of greedy-like methods. Those include Compres-sive Sampling Matching Pursuit (CoSaMP), Subspace Pur-suit (SP), and Iterative Hard Thresholding (IHT). Our resultsshow that the denoising obtained with these algorithms isa constant and a log-factor away from the oracle's perfor-mance, if the signal's representation is sufficiently sparse.Turning to practice, we show how to convert these algorithmsto work without knowing the target cardinality, and insteadconstrain the solution to an error-budget. Denoising tests onsynthetic data and image patches show the potential in thisstagewise technique as a replacement of the classical OMP.
EUSIPCO-Denoising-Guarantees.pdf (91.49 Ko) Télécharger le fichier
inria-00623895 , version 1 (15-09-2011)
  • HAL Id : inria-00623895 , version 1
Raja Giryes, Michael Elad. DENOISING WITH GREEDY-LIKE PURSUIT ALGORITHMS. The 19th European Signal Processing Conference (EUSIPCO‐2011), Aug 2011, Barcelona, Spain. ⟨inria-00623895⟩
83 Consultations
64 Téléchargements
