Characterization of the value function of final state constrained control problems with BV trajectories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications on Pure and Applied Mathematics Année : 2011
This paper aims to investigate a control problem governed by differential equations with Radon measure as data and with final state constraints. By using a known reparametrization method (by Dal Maso and Rampazzo [18]), we obtain that the value function can be characterized by means of an auxiliary control problem of absolutely continuous trajectories, involving time-measurable Hamiltonian. We study the characterization of the value function of this auxiliary problem and discuss its numerical approximations.
Briani-Zidani.pdf (472.09 Ko) Télécharger le fichier
inria-00627518 , version 1 (28-09-2011)
Ariela Briani, Hasnaa Zidani. Characterization of the value function of final state constrained control problems with BV trajectories. Communications on Pure and Applied Mathematics, 2011, 10 (6), pp.1567-1587. ⟨10.3934/cpaa.2011.10.1567⟩. ⟨inria-00627518⟩
255 Consultations
147 Téléchargements
