Approximation Schemes for Monotone Systems of Nonlinear Second Order Partial Differential Equations: Convergence Result and Error Estimate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Differential Equations and Applications Année : 2012
We consider approximation schemes for monotone systems of fully nonlinear second order partial di erential equations. We rst prove a general convergence result for monotone, consistent and regular schemes. This result is a generalization to the well known framework of Barles-Souganidis, in the case of scalar nonlinear equation. Our second main result provides the convergence rate of approximation schemes for weakly coupled systems of Hamilton-Jacobi-Bellman equations. Examples including nite di erence schemes and Semi-Lagrangian schemes are discussed.
briani_camilli_zidani_finalversion.pdf (192.43 Ko) Télécharger le fichier
inria-00627520 , version 1 (28-09-2011)
Ariela Briani, Fabio Camilli, Hasnaa Zidani. Approximation Schemes for Monotone Systems of Nonlinear Second Order Partial Differential Equations: Convergence Result and Error Estimate. Differential Equations and Applications, 2012, 4, pp.297-317. ⟨10.7153/dea-04-18⟩. ⟨inria-00627520⟩
455 Consultations
680 Téléchargements
