Towards a storage backend optimized for atomic MPI-I/O for parallel scientific applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Viet-Trung Tran
  • Fonction : Auteur
  • PersonId : 885093
We consider the challenges of building data management systems that are optimized for parallel I/O of scientific applications. One of those challenges focuses on the requirement of high I/O throughput for concurrent data accesses while obeying MPI atomicity semantics. In most existing implementations, the atomicity is often implemented through locking-based schemes, which have proven inefficient. In this proposal, we argue that a novel versioning-based scheme can avoid the need to perform expensive synchronization by using multiple snapshots of the same data, which is much more efficient. We describe our prototype of a versioning-based storage back-end and report on promising experimental results.
paper.pdf (43.23 Ko) Télécharger le fichier
inria-00627667 , version 1 (29-09-2011)
  • HAL Id : inria-00627667 , version 1
Viet-Trung Tran. Towards a storage backend optimized for atomic MPI-I/O for parallel scientific applications. Parallel and Distributed Processing Workshops and Phd Forum (IPDPSW), May 2011, Anchorage, United States. ⟨inria-00627667⟩
146 Consultations
198 Téléchargements
