EXAMPLAR-BASED INPAINTING BASED ON LOCAL GEOMETRY
In this paper, we propose a novel inpainting algorithm combining the advantages of PDE-based schemes and examplar-based approaches. The proposed algorithm relies on the use of structure tensors to define the filling order priority and template matching. The structure tensors are computed in a hierarchic manner whereas the template matching is based on a K-nearest neighbor algorithm. The value K is adaptively set in function of the local texture information. Compared to two state of the art approaches, the proposed method provides more coherent results.
Traitement des images [eess.IV]
LeMeur_icip2011_inpainting.pdf (3.64 Mo)
Télécharger le fichier
LeMeur_icip_2011_poster_inpainting.pdf (876.51 Ko)
Format : Autre
